No linkable item found in Devonthink
I bought Hook to use with Devonthink and downloaded Hook yesterday. But everytime I try to use Hook with DT I get the message that “No linkable item with Devonthink”. I have the latest version of DT3 and Hook works OK with other apps. Can anypne help?
Thanks in advance
Might be worth running Hook > Preferences > Updates > Check Now, which ensures that you have the latest set of scripts for each application.
You might be experiencing the same situation that another user had with Hook not working with Chrome. Substitute “DEVONthink” for “Chrome” and follow the advice.
welcome to the Hook Productivity Forum, @peedwards. Sorry you encountered a bump on the road. I’ve just run another test with Hook 1.4 (public version) in context of DT3 (3.0.4) and it works for me.
Are you still having an issue after checking automation and scripts, per the comments above?
Luc
Thank you. The DevonThink wasn’t checked in the panel in System Preferences > Security & Privacy > Automation. Seems to work now.
I am aiming to use Hook to support my History research - looks encouraging.
Peter
