Hook Version 3.3 public BETA 4 (4531; Integration v. 182) is now available for testing..
The big change in Beta 4 is that background mode is the default again. You can change the mode of operation ( background , foreground) using a terminal pref as described in the release notes.
Please consider putting the individual slides in the “Tutorial Slideshow” on a loop (repeat endlessly)? As it is now in 3.3b4 once a slide’s animation is over if we want to see the animation again we have to advance to the next slide then back again.
Alternative would be to have the repeat icon appear on top of the slide when its animation end. When clicked, the slide repeats. Just a small quality of life change for those of use who want to savor the tutorial a bit more
