Sorry if this is a stupid question but since Hook started “living” in my dock there is a badge on it that doesn’t go away. I like having Hook in my dock but the red badge is a distraction. Am I doing something wrong?
Thank you for the notice. It seems we had saved/previewed but not actually published the update. Very sorry about that.
the Hook 3.3 public BETA – Hook page is now updated.
You may still get a more recent integration script number since we can release scripts on the integration server after the Hook.app dmg is built.
I installed the update Version 3.3 Public Beta (4522; Integration v. 180). When I go to activate Hook after rebooting I got a license agreement window (or at least I think it is) and a dmg image ends up on my desktop. This happens twice, after that, the application works fine. Any ideas?
If you previously launched Hook from a DMG, rather than the app folder, then macOS might remount the DMG. please discard old Hook DMGs in that case (YOu can keep a compressed version of it if you like.)
Thanks for the reply. Closed the app and opened directly from Hook.app in the application folder. I guess it was launching of the older dmg after reboot as I have it launch automatically. Works now. Appreciate your prompt reply.
Hook 3.3 public BETA 4 available for testing as described in this forum topic, so I’m closing the current topic, to keep the discussion focused on the the latest beta.
