TaskPaper 3 combines plain text files with a very rich scripting API (key-value tag processing, outline-aware filtering, folding etc etc).
This allows us to write Hook scripts for capturing and following links which can preserve not only file path but also any other aspects of editor state which we might be interested in, for example:
- Filter state,
- fold state,
- selection start and end.
Here is an illustrative draft of sample scripts for Hook in which:
Get Addresscaptures the current filter state of the TaskPaper 3 document, as well as its file path -
Open itemopens the linked file and also restores its filter state from an option in the link.
Open Item
use framework "Foundation"
on run
tell application "TaskPaper"
set fpOption to my decodedPath(text (1 + (length of "taskpaper://")) thru -1 of "$0")
set xs to my splitOn("?", fpOption)
open item 1 of xs
activate
if 1 < length of xs then
set kv to my splitOn("=", item 2 of xs)
if 2 ≤ length of kv then
set k to item 1 of kv
set v to item 2 of kv
if "filter" = k and "" ≠ v then
tell front document
evaluate script "e => e.itemPathFilter = " & my quoted("\"", v)
end run
-- GENERIC
-- https://github.com/RobTrew/prelude-applescript
-- decodedPath :: Percent Encoded String -> FilePath
on decodedPath(fp)
tell current application
(its ((NSString's stringWithString:fp)'s ¬
stringByRemovingPercentEncoding)) as string
end decodedPath
-- quoted :: Char -> String -> String
on quoted(c, s)
c & s & c
end quoted
-- splitOn :: String -> String -> [String]
on splitOn(pat, src)
set {dlm, my text item delimiters} to ¬
{my text item delimiters, pat}
set xs to text items of src
set my text item delimiters to dlm
return xs
end splitOn
Get Name
tell application "TaskPaper" to name of front document
Get Address
on run
set fp to (POSIX path of ((file of front document) as alias)) as string
tell front document
set strFilter to evaluate script "e => e.itemPathFilter"
if "" ≠ strFilter then
set strOptions to "?filter=" & encodedPath(strFilter)
set strOptions to ""
"taskpaper://" & encodedPath(fp) & strOptions
end run
-- encodedPath :: FilePath -> Percent Encoded String
on encodedPath(fp)
stringByAddingPercentEncodingWithAllowedCharacters:(its NSCharacterSet's ¬
URLPathAllowedCharacterSet))) as string
end encodedPath
