I’m absolutely loving Hook so far and I need some help with something.
Sometimes when I invoke Hook with the keyboard shortcut, keystrokes produce that “error bump” sound or whatever it’s called and, of course, nothing happens. If I press tab twice, I am then able to navigate the list with the arrow keys to select whatever command using the “enter” key.
This is not consistent, however, and sometimes I get no error bump sound and everything works as expected. I can imagine the problem here is between my keyboard and chair. Can someone tell me what I’m doing wrong?
Other than that, I can hardly wait to spend money on this app. This thing is life-changing.
When I hear the “error bump” (I call it the “bonk” sound – Apple calls it “basso”) it’s usually because the keys pressed or shortcut used interferes with another shortcut or command that the app I’m using expects to receive. I.e., a conflict.
I’ve seen something like this occasionally when I first launch Hook. Others here haven’t been able to reproduce it yet. Then it goes away. Is this when you see it too?
With a note selected in the notes pane, I invoke the Hook window with keyboard shortcut (⇧⌃⌥⌘ - space for me).
With the Hook window visible, any keystroke triggers the “basso” sound (thanks, quorm for the info), except for tab. One tab stroke moves focus to and highlights the gear icon and a press of the space bar will activate the gear menu. A second tab stroke moves focus to the command list (or whatever the official designation is for the main part of the window) and everything seems to work as expected from there.
Quite often, though not always, the invoking of the Hook window in this manner triggers that whooshing electronic trill. I don’t know what that one’s called, either. But I’m sure everyone’s heard it at some point.
That’s as far as I’ve had a chance to investigate it so far. Anything else I should try?
It looks like in context of Bear, for some users , sometimes the gear menu has “focus”. That explains why hitting the tab key solves the problem. We’re investigating this.
