All Bookmarks not showing all bookmarks
I am testing Hookmark (again) and I am on the basic 7.3.1 version with Sequioa 15.7.3. Using Firefox and Brave. Bookmarking problem exists with both browsers.
When creating a new hook with CTRL-H the message in the window says that the hook for the website is created. When looking unter All Bookmarks the hook isn’t showing but it is showing under Recent.
What I did so far:
  • deleted ~/Library/Application\ Support/com.cogsciapps.hook/ folder
  • restarted my mac
But I couldn’t resolve the issue. How to I force the created bookmarks (hookmark websites for example) to show under All Bookmarks.
Thanks.
In addition to the above:
  • Problem exists with Safari bookmarks as well
  • when I tag a bookmark in the Bookmark window the counter for All Bookmarks goes up but the bookmark doesn’t show under All Bookmarks.
  • Bookmarks show without a problem under Recent
  • when I search in All Bookmarks for a bookmark in Recent and afterwards search in All Bookmarks for the bookmark it shows
That’s strange. I have not encountered or heard other reports of this issue. deleting ~/Library/Application\ Support/com.cogsciapps.hook/ folder would certainly delete all your bookmarks. And deleting it should not be necessary to resolve this issue.
Can you please start Console.app, and start streaming, and type in the search field. Now invoke the Hookmark window. Pause streaming. Copy and paste the Console output into a plain text file, compress the file and email it to support@hookproductivity.
I filed a partly similar report here:
Looking at the history in our systems, I see @bchend has seen this problem. I can’t replicated it. She will look into it early next week.
Do you add the bookmark via ⌘D (Add Bookmark) or via Copy Link or Hook to Copied Link?
I don’t really remember, but most likely by “Add Bookmark”.
Just dragged a file into the Bookmarks window. It took a couple of seconds but eventually the bookmark showed up in the list, as expected.
Thanks. That’s less serious than I thought. We’ll look at speeding it up.
My bookmarks are not showing up at all under ALL Bookmarks (after more than 24h). I think this is serious.
Sorry about this issue, @maropa29 .
Just want to confirm: after you used Ctrl+H to invoke Hookmark on a web page, did you do “Copy Link” either via Hookmark Action menu->Copy Link or Command+C?
I used the Hookmark Action menu → Copy Link
Thank you, @maropa29 .
If you close Bookmarks window and open it again, will the bookmarks show?
After the search, do all bookmarks show or only the bookmarks in the search result show?
