I am able to work with invoking hookmark context window Shift + Command + space ( ctr +H would also work) t and then copying markdown link by shift+command+M in H6 or command+M in H5.
When I am trying to directly invoke copy markdown link with 'Shift+^+CMD+M` sometimes I am getting link to the item, but sometimes only link to the app
A few days ago the official version of zotero7 was released, I updated to zotero7 and installed the zotxt plugin, the version of hookmark is 6.3 and the script version is 333, but as shown in the picture, the hookmark does not work properly.
I’m trying to get this to work as well with Zotero 7.0.1. In Zotero, when looking at “Item Format” in settings, “Markdown Item from URI” does NOT exist in the list (went to bottom of list).
First of all, thank you for your work. When I tried to link Zotero 7 entries with other content, I encountered the issue shown in the image. I have followed the troubleshooting steps outlined in this post and confirmed that Zotero is configured correctly, but the problem still persists. What’s even more puzzling is that after completely uninstalling and reinstalling Hookmark, it worked successfully the first time and showed an item that could be linked! However, frustratingly, just a few minutes later when I tried to hook another article again, the same issue reappeared. Could someone please tell me how to resolve this problem?
FWIW, I had the same issue, after having done everything specified earlier. What turned out to be needed was to force the association of “Copy as Markdown Item URI” with the keyboard shortcut, via the macOS Settings app (Keyboard > Keyboard Shortcuts > App Shortcuts):
I think I understand why—I set the Hookmark shortcut key to Option + H, which often causes the modifier key to still be pressed when triggering scripts.
Sorry about this issue and thank you for reporting it, @SongshGeo .
We have just updated our script server with the fix, script version 369. Could you please update your local script(Hookmark Settings window->Update->Check now) and see if it resolves the issue?
