Am I missing something?
that’s strange. Could you please try rebooting Hook to see if it comes back? Are you using Hook 2.2.2?
2.2.2 yes. And I restarted it just now, nothing.
So… nothing? Problem still exists on my side.
Are you using Hook Pro or Hook Essentials?
Essentials. Is this feature not available in Essentials? If not, I’ll upgrade
Correct, script editing is a Pro feature. Sorry I should have zeroed in on it when you first asked the question. (I think most people on the forum use the Pro version.)
