How do you archive Hook links so they are search via Alfred?
Please follow the link in my original post, download the zip file, unzip it and open the file with the .alfredworkflow extension, which will import the Hook workflow into Alfred. Then type hm and your search term and it will search through all of your Hook bookmarks, it’s super handy.
You don’t need to do anything special with Hook to make them visible to the Alfred Workflow, just bookmark items as usual. The Alfred Workflow searches the Hook database directly.
If you would like to see the code that the workflow uses, jump into Alfred, go to Workflows → Browse Hook Bookmarks → double-click hm and then inspect the Apple Script.
If enough Hookmark users request the API from Raindrop.io’s dev, perhaps Raindrop will do it.
