When I use hook scheme to open suffix file bike, the following prompt appears (bike software is closed)
The document “1.bike” could not be opened. You don’t have permission.
To view or change permissions, select the item in the Finder and choose File > Get Info.
When I open the link using the bike solution, the prompt is this
Problem Opening Link
Failed to find any documents matching the link: bike: /kqlUh6Ml/#9T9k
I hope the developers test again after the bike is closed, open the file, hook this script has a problem, don’t developers fix it, the high cost of software should have the corresponding service
macOS Monterey
版本12.6.8
Version 5.1.3(5475; Integration v. 286)
The problem will always recur, I hope you will test the bike off, and then click the link, you can see if it can go back
Sorry so far I have no luck to reproduce the problem.
What’s your Bike’s version? Is your Bike from App Store? Is it possible that you make a small video which can show the problem and send it to support@cogsciapps.com?
