macOS Version 14.2 (Build 23C64)
Hook Version 4.0 (4988; Integration v. 238)
Hookmark(Setapp) Version 6.0.1 (5788; Integration v. 299)
Hi!
I’m a VoiceOver (screen reader) user and have been using Hook for a few years. I downloaded the Setapp version of Hookmark. Before that, used Hook 4 directly. When I invoke Setap Hookmark on a Finder item, Safari tab, a Drafts document or any another type of file, I get: “No linkable item found in Hookmark”. However, it is not true because when I press ⌘C I get the url in the clipboard. Furthermore, I use Alfred workflow and there can I browse through the bookmarks.
So it is definitely something wrong that VoiceOver reads No linkable item found in Hookmark when it is clearly that those bookmarks are there.
Also, can confirm that those 2 bookmarks exist by going to the Show Bookmarks window button in Hookmark itself.
When I’m running an older version of Hook, then those files are detected by Hook as it should.
I downloaded latest version of Hookmark directly to check if it is something wrong with Setapp version. I get same annoying notification: “No linkable item found in Hookmark”.
I hope you could look at that issue and I will gladly to give more feedback if needed!![]()
