I am having trouble finding the usefulness of Hook. I get that it is helpful to link disparate pieces of material together, but I cannot understand how to implement this app into my workflow.
Invoking the Hook window provides little help as it only lists other links/docs/hook etc. It would be much more helpful if Hook had a window or app-like instance where each hooked item is a node in a network with lines connecting it to the other linked items. A map like this would be much better and useful than simply a list of hooked resources.
Does anyone else feel like this or similar? And, if so, how have you changed your workflow or what have you uncovered to make Hook more useful? I could certainly just not be understanding something or not be using it effectively, but after sitting with this for a few days I wanted to get other opinions. Thanks!
