Version 174 of Hook integration updates support for Tinderbox bringing the integration to version 9 of the Tinderbox Mac app. It also adds preliminary support for Notion Mac app app
Version 173, added 2021-07-23, provides support for GoodLinks. See Using Hook With GoodLinks
Languages
Tinderbox and GoodLinks support because those apps are truly linkable., i.e., also via automation.
Notion support is UI-scripted, and hence language dependent. However, the scripts can easily be adapted to any language.
We have requested (again) of Notion that they provide an app API. Their API is web-based: not much use in the app itself.
How to get the updated integration
Hook’s automatic software update (if enabled) automatically updates Hook’s integration scripts without you needing to relaunch Hook. Using Hook’s Check for App Updates and Update Scripts command also updates the scripts, without you needing to relaunch Hook.
Revision History
- 2021-07-30 10:52: corrected: Tinderbox 9.
