I need help with Shortcuts and using Hookmark. I would like to integrate this functionality into a current workflow that I have to makes reminders out of text in a Note in Notes.app
So what I need to do is to get the hook:// link to the Note that I am currently in.
End result is to add the hook link into the reminder in the URL field, so I can go from the Reminder back to the Note. (But that’s irrelevant).
But for some reason I can’t figure out how to create a Hookmark link using Shortcuts using the official Hookmark shortcut actions.
In that case, You can either use Apple Notes’s shortcut actions to get current note’s creation timestamp so you can get its url: hook://notes/dt/timestamp.
Or you can try Apple Notes’s Get Address Script from Hookmark Settings window->Scripts->Notes->Get Address, and run the script in a Run AppleScript action in Shortcuts.
I think it would be handy then to have a shortcut that ran the get address script and returned the address. There is no way to get a note’s timestamp via shortcuts. I could run the AppleScript I suppose.
