Using Hook with Yoink
I use Yoink as a shelf for holding my files. Currently I have to navigate to the file location in Finder to be able to generate a hook link. Is it possible to link items directly from Yoink?
https://eternalstorms.at/yoink/mac/
Thank you for the feature request, @ashish .
I just checked Yoink. It seems it does not have the API which allows Hookmark to get the selcted file URL.
We will try to contact them. In the mean time, you can also contact them. We have an email template regarding this.
