Using Heptabase with Hookmark
Heptabase has already supported Deeplink in its updates, and the deeplink can be changed to the heptabase:// format to support opening in the desktop app. I would like to ask if there is a possibility of implementing integration between Hookmark and Heptabase?
Thank you!
Thank you for this request, @JacobJia211 .
We have updated our script to include the support for Heptabase, script verson 368, @JacobJia211.
However, it seems there’s no way for Hookmark to retrieve the block title—so it uses the URL as the title by default. You’ll need to manually change the title in Hookmark.
If the Heptabase team could provide a shortcut that returns both the title and link in Markdown format, that would be ideal.
Please go to Hookmark Setting windows->Update-Check Now to update your local script. You might need to restart Hookmark.
Thank you so much! It works perfectly!
I will contact Heptabase’s customer service to see if they can support this change. I’m very glad that both products I use have such supportive teams.
Hello!
The Heptabase team told me that they have already supported the feature to get the Tab Title. Could you please check if the Hookmark script can be further improved? If not, the Heptabase team said they would be happy to know what else needs to be provided.
Thank you!
Thank you, @JacobJia211 .
We have updated our script script server to display the Tab title, script version 370. Please update your local script(Hookmark Settings window->Update-Check now) to get the this fix.
