Transferring sync from Dropbox to iCloud
Hi,
I’ve just downloaded Hookmark Pal, which I understand relies on iCloud syncing. However, I have many years of synced links held in a Dropbox folder.
What steps do I need to take to move from Dropbox Syncing to iCloud Syncing, without losing any of existing links?
E.g. if I just change the setting in Preferences, will everything Just Work™, or are there other steps I should take to guaranteed I don’t lose anything?
Thanks in advance…
Thank you for contacting us, @brookter .
On your Mac, you can change the setting in Hookmark Preferences and switch to iCloud sync, and configure settings in System Settings for iCloud sync. That should be enough.
Please let us know if you encounter any issues.
That’s great – thanks for the quick reply!
