I just updated my QSpace Pro to V4.2.2 (257). Hookmark no longer recognizes a linkable object in QSpace Pro when a file is highlighted and Hookmark is invoked.
It worked pre-update earlier today.
Thank you for reporting this issue, @chuckl .
We just added the fix to our script sever. Could you please update your script (Hookmark preferences window ->Update->Check now) and see if it fix the issue?
The latest version is 309.
I should’ve waited for today’s Hookmark script update before reporting the issue, as it is now fixed.
Thanks Hookmark and/or QSpace. You guys are fast!
