If you are using Bartender 3 and are not yet on macOS Mojave, then please note that if you enable “use dark menu bar and Dock”, you currently will not be able to see the Hook menu bar icon. We might be able to address this, but in light of the other tasks on our list, and that this only affects a very small % of users, and there’s an easy work-around, it is not currently a high priority.
Our very near-term task list includes
- improving the onboarding wizard/assistant;
- a FireFox drag and drop issue;
- supporting Ulysses and Drafts, and
- dealing with a “Link to New” issue with OmniFocus 3
several of these items are discussed in this forum.
