First off, thanks for adding “Find” to Hook!
A few features that would be nice additions:
- Up and Down arrows immediately allow you to select from results (without pressing “Tab” or even without entering a query because the result is already visible)
- Real-time search as you type (no need to press “Return”)
- Fuzzy-search option
Thanks for the consideration!
