I’m a big user of Spark email…I know it’s not the best for use with Hook, but overall, it does seem to be working fine with scripts… That said, the one issue I do see is that if I search for an email, and then try to get a URL for that email (ie, Control H), nothing shows. If I then go into Archives and scroll back in dates to the actual email (ie, not from the search results), Hook is working again and can “recognize” that email and provide a link.
I suspect there is no way to fix this, but thought I’d see if anyone has an idea here… thanks!
