You are right. Hookmark does not support Spark Desktop from App Store.
We just updated our script server with the fix for this issue, version is 386.
You can update your script (Hookmark settings window->Update->Check now) and click on “Reset to default” button in Scripts→Spark Desktop APP Store. This will allow you to get future updates for this app.
The script works fine now when I click on CTRL+H in Spark desktop from APP store, however when I am browsing a thread, the Menu Bar hookmark doesn’t automatically detect/show a little counter saying that this thread has a Hookmark. Is this working as expected?
This is because Hookmark uses UI-based script to integrate with Spark. The counter is not able to work properly. Once Spark has AppleScript support, we will update the script and the counter will work.
