Soulver 3 stopped working with Hookmark. I used to be able to link to individual Soulver 3 sheets. However, suddenly Hookmark only links to ‘Default.sheetbook’. When I invoke Hookmark to return to Soulver, it returns only the most recently updated Soulver sheet instead of the sheet originally selected.
Here’s teh AppleScript for integration with soulver.
delay 0.1
set the clipboard to ""
delay 0.2
tell application "System Events" to tell process "Soulver 3"
if menu item "Copy a Link to open Sheet" of menu 1 of menu bar item "Sheet" of menu bar 1 exists then
click menu item "Copy a Link to open Sheet" of menu 1 of menu bar item "Sheet" of menu bar 1
click menu item "Copy Link to Sheet" of menu 1 of menu bar item "Sheet" of menu bar 1
delay 0.05
delay 0.05
set myUrl to the clipboard
set myTitle to name of window 1
return "[" & myTitle & "](" & myUrl & ")"
it hasn’t changed. Has anything changed in Soulver?
UI scripting is not very reliable. I would ask the Soulver developer to spend a few minutes to provide an API for linking:
I went into the Hookmark settings to find that Soulver isn’t included in the applications list. I clicked ‘+’ to add Soulver, but encountered a complication—I’m not able to add scripts. Please see screenshot.
