I’m curious. I’m running Curio 15 and Hook 3.0.
When I try to hook a Curio Project, I can’t get any links to it, let alone deep linking to any figure inside it.
Is there a bug, or am I missing something?
I can’t think of a reason why the Curio integration would have been affected in 3.0. Did you reinstall Hook ?
We did make a change last summer with Curio, and shared the old integration online. There are two major options: to use hook://file/ URLs or Curio’s native URLs. There are various tradeoffs, which are described in Using Hook with Curio – Hook. Does that page address your issue? If not, please let us know and we’ll dig deeper.
===== UPDATE 30 MINUTES LATER ====
After retesting, Hook 3 and Curio 15 integration work as expected in both cases (“native integration” and deeplink script)
I’m happy, but the god’s of IT will drive me nuts.
Ok, this is really weird. I tested all possible configurations of :
- Hook (v 2.2.2 vs 3)
- Curio (14 vs 15)
- the Hook integration (native integration or special script for deep linking)
Here are the results:
| Hook Version | Script | Curio Version | Result |
| 2.2.2 | Native Integration | 14 |
hook:// Link to high level document (.curio) whatever is selected inside. Markdown name not formated |
| 2.2.2 | Special Script | 14 |
curio:// link to the idea space or to the figure that is selected. Markdown name formatted |
| 2.2.2 | Native Integration | 15 |
NO LINK AT ALL |
| 2.2.2. | Special Script | 15 |
| 3 | Native Integration | 14 |
NO LINK AT ALL |
| 3 | Special Script | 14 |
| 3 | Native Integration | 15 |
NO LINK AT ALL |
| 3 | Special Script | 15 |
Bottom line is:
- the special script works in all versions (which is fine by me since I want deep linking)
- Curio 15 DOES NOT WORK with hook 2.2.2 nor hook 3 without the special script for deep linking
- Curio 14 DOES NOT WORK with hook 3 without the special script for deep linking,
I’m really not sure what is going on. Can anybody reproduce these results? Or is there something weird with my machine?
PS: I’m cross posting this to the Curio Forum: Hook 3 + Curio 15 not working together? - #3 by seishonagon - Support Questions - Zengobi Forums
NO LINK AT ALL
