I am getting quite comfortable with Hookmark but I see an issue I’m hoping someone can explain. I’m in Bear and I want to copy a Hookmark link to the note I’m viewing and paste it into a document in Scrivener. If I click the menu bar icon and activate the Hookmark action window, then click the Copy icon there, when I paste that link into Scrivener I get the clickable TITLE of the Bear note. This is what I like to happen.
When I use a hot key combination that I’ve defined in Hookmark’s preference panel, and use that hotkey combo to create the copied link, the pasted link appearance is messy, showing me the link itself rather than the note’s title. Is this normal or can I change the hotkey combo to display the pasted link using the note’s title easily?
