As of today, I can’t link a note to an email message. I’m working on a macbook pro and using apple-mail.
Are there others experiencing the same problem?
Are you using Ventura? If so, have you updated to Hookmark 4.0? It adds support for Ventura notes
I’m using Ventura and I have updated to Hookmark 4.0.
Not only it doesn’t work together with notes,… If I copy a link to pages it doesn’t work either.
I can’t replicate issues with Apple Mail or Notes on Ventura. No other reports so far. Perhaps an incompatibility with one of your other apps and Ventura? Are you using a clipboard manager?
Could you please share some screenshots with specific steps here or via Private message or email? To help us decode " can’t link a note to an email message"
Are you seeing No linkable item found in <App>
Hi, thank you for your reply…
I have done some tests…you find the results in the pages document.
(Attachment Hook test.pages is missing)
the resolution is too low for me to tell.
However, I think you say you are using a clipboard manager. That must be the problem.
I’ve changed the category and renamed it accordingly.
