Repeated crashes on 7.3.1
Updated Hookmark to 7.3.1 and Hookmark and Hookmark crashed. Unable to relaunch it. Downloaded the latest version and crash on launch continued. Same after a reboot. Using an M3 iMac with macOS 27.0.1
Basic crash summary:
Translated Report (Full Report Below)
Process: Hookmark [8539]
Path: /Applications/Hookmark.app/Contents/MacOS/Hookmark
Identifier: com.cogsciapps.hook
Version: 7.3.1 (6695)
Code Type: ARM-64 (Native)
Role: Background
Parent Process: launchd [1]
Coalition: com.cogsciapps.hook [1124]
User ID: 501
Date/Time: 2026-10-05 14:56:10.0565 -0700
Launch Time: 2026-10-05 14:56:09.3219 -0700
Hardware Model: Mac15,5
OS Version: macOS 27.0.1 (26A434)
Release Type: User
Crash Reporter Key: 852BEE69-2536-446E-43BB-5E09DDDDB4E5
Incident Identifier: 655B5EE6-28E0-41F1-B21E-B9B6325B9A3B
Time Awake Since Boot: 2000 seconds
System Integrity Protection: enabled
Triggered by Thread: 0, Dispatch Queue: fmdb.<FMDatabaseQueue: 0x781493b9f0>
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11, Segmentation fault: 11
Terminating Process: exc handler [8539]
VM Region Info: 0 is not in any region. Bytes before following region: 4303388672
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 100808000-100ac0000 [ 2784K] r-x/r-x SM=COW /Applications/Hookmark.app/Contents/MacOS/Hookmark
Application Specific Backtrace 0:
Thanks. Mark
Thank you for reporting this issue and sorry about this!
We will look into it and fix it as soon as possible.
You can download Hookmark 7.2.2 from here:
Does revert to Hookmark 7.2.2 work for you, @mprazoff ?
I can’t find the crash report for iMac. Do you have Thread 0 backtrace?
Could you please go to /Applications/Utilities/Console->Crash Reports and see if there are any crash reports for Hookmark? If yes, please send us the report.
Thanks for your continued support. The reversion to 7.2.2 worked, although oddly the app icon is not visible in the dock, only the black dot showing something running. Weird. Here is the full crash log. Regards.
