This set of scripts adds timestamps to hooks in QuickTime Player. That way, if you do a Hook to New then the new note will be linked to that time, or if you manually add links to a note they will also be linked to the relevant times.
Unfortunately, this script (I think) loses track of files if they are moved — @LucB is that right? Is there a way to access Hook’s secret sauce to locate a file instead of relying on the path? This also means the links won’t work on another machine, unless the video is in the same location.
Please let me know if this works for you and any suggestions for improvements.
Open Item
Remember to set the url scheme to “quicktime”
set AppleScript's text item delimiters to "UUID="
set theItems to every text item of "$0"
set AppleScript's text item delimiters to ""
set theTime to text 18 thru -1 of the first item of theItems
set encodedUUID to the last item of theItems
set theUUID to do shell script "python -c \"import urllib, sys; print (urllib.unquote(sys.argv[1]))\" " & quoted form of encodedUUID
tell application "QuickTime Player"
open file (theUUID as POSIX file as text)
set current time of the front document to theTime
Get Name
return name of front document
Get Address
set theVideo to the front document
set theTime to theVideo's current time
set theFile to file of theVideo
set theUUID to POSIX path of theFile
set encodedUUID to do shell script "python -c \"import urllib, sys; print (urllib.quote(sys.argv[1]))\" " & quoted form of theUUID
return "quicktime://time=" & theTime & "UUID=" & encodedUUID
