Lately Hook is unable to link to my PowerPoint presentations. Hook 3.4 is properly authorized and works as it should in all cases that I have tried, with the exception of PowerPoint.
I have just switched to the Apple M1 chip computer and now run Monterey 12.3. Might this have any bearing? I use PowerPoint 16 for Mac.
I can create a link with Hook if I work from Finder — just highlight the file in Finder and then Hook it. Is the the only way to work with ppt presentations?
I do not have OneDrive enabled. Also, the message Hook returns is a bit different than the one in the example in the discussion you referred me to. It is:
I’ve test on a M1 with macOS 12.3.1 (latest for M1) using several powerpoint files, and it works for me.
Could you please check Hook > Preferences> Scripts Tab > Microsoft Powerpoint ? If there is a * next to the name of the app, that means it’s been overridden.
then please cick on the Get Address tab there. Do you see this?
tell application "Microsoft PowerPoint"
set activeDoc to active presentation
set activeDocName to name of activeDoc
set activeDocPath to path of activeDoc
set fullURL to full name of activeDoc
if fullURL does not start with "http" then
return "file://" & POSIX path of fullURL
set appURL to "ms-powerpoint:ofe|u|" & fullURL
If not perhaps the ~/Library/Application\ Support/com.cogsciapps.hook/DefaultAppAppleScript.plist is corrupted it. If so you can quit Hook, delete that file, and then relaunch Hook.
I am having the same problem. The suggested solution (quit Hook app for a moment, delete ~/Library/Application\ Support/com.cogsciapps.hook/DefaultAppAppleScript.plist., relaunch Hook.
) fixed the problem only temporarily. After closing the PPT and reopening it, the same problem occurred again. Any suggestions? My system: Monterey 12.3 (21E230)
Thanks for reporting, @Morheene . Not clear to me at this point why the file would be corrupted. If you have a Pro license, could you please copy/paste the Powerpoint integration script here (or whatever app you’re having problems with): Scripts Tab – Hook. This is to verify whether it the file is in fact corrupted. That would tell us what we need to do.
tell applicause scripting additions
use framework “Foundation”
property NSURL : a reference to current application’s NSURL
tell application “Microsoft PowerPoint”
set n to full name of active presentation
set fp to POSIX path of n
set rawUrl to NSURL’s fileURLWithPath:fp
set f to rawUrl’s absoluteString
return f as string
end telltion “Microsoft PowerPoint” to get “file://” & full name of active presentation
After reading the latest messages I tried again to link to a PowerPoint presentation and for me (like Morheene) the problem again occurs.
Is this the script you are asking about?tell applicause scripting additions
return f as string
use framework "Foundation"
set rawUrl to NSURL's fileURLWithPath:fp
set f to rawUrl's absoluteString
return f as string
Hook’s integration server has been updated. Version 211 has the fix. Sorry all: this was a copy/paste error. Missed it in testing due to having previously overridden my version of that script. We need to make the script-override symbol [currently *] more salient (particularly for long bundle names).
