Possible issue with Bookends and Hookmark
Hello,
I’m troubleshooting a bug with Bookends and it seems there is a possible issue with Hookmark. I’m writing just to see if anyone has any thoughts or insight into this issue.
In the Bookends format manager, I have been unable to save custom field orders for citations. While working with Sonny Software’s creator, Jon, and not finding any obvious solutions, I recalled how I once had a mysterious bug related to Things 3 and Hookmark. The solution for that was to disable Hookmark’s feature “show current item’s number of hooks in menu bar icon”. I figured I’d give it a try and it seems to have solved the issue.
Does this make any sense? Any thoughts?
Thanks!
Thank you for reporting this issue, @michaelAF .
The format function(for title) in the script causes this problem. The script has been updated, version 283.
Could you please update your script and see if it solves the issue?
