I can’t click hooklinks pasted into excel anymore. Excel is the same version, but Hookmark has updated to Version 6.0 (5779; Integration v. 300).
I don’t think it’s cell format related. Anything I can do?
Before:
After recent update:
Before:
Figured it out!
I had a problem with copy and paste formatting so I was using a program called “Pure Paste”. If you use this app, just disable it’s ability to automatically clear clipboard formatting and use a new PASTE shortcut instead. Then give PurePaste accessibility access by going into accessibility, press +, and then add purepaste by browsing to it.
This also fixes “Hook to copied link” being greyed out (grayed out)
I hope this helps someone
Thank you for the information! I am glad you figured it out.
