Hello everybody,
I am a new user of Hook.
I would like to use it with Papers 3.4: I read the app is listed in the linkable app (and read in the forum many of you are using both the apps).
But (there is a but, of course) when I evoke Hook the app return a "no linkable item found in Paper 3.4)
Since Hookmark does not work with Papers 4.x, it would be very helpful if this is not incorrectly stated on the website. I would appreciate it if you could correct the information on the website https://hookproductivity.com/what-mac-apps-are-compatible-with-hook-app as I bought Hookmark just for this feature. It would be even better if you would contact the Papers programmers so that Hookmark might work with Papers in the near future.
Thanks for your effort
