I’m creating a large project portfolio in Omniplan. I’ve already used @RobTrew’s script to hook with individual projects and tasks. For example, each (sub)project has a link to the Folder on disk where all the actual deliverables, reference material etc will be stored.
( as a side note, I’m interested to know if there’s a reason (other of course than extreme busy-ness) why the OmniPlan scripts are not part of the script bundle? They seem solid)
I do need some help to take the integration a step further. Whenever I link an item from anywhere TO omniplan, I’d like the hook link to be pasted at the end of that particular task note.
This is what i get “manually” (I simply retrieve the hook link a second time from hook itself after pasting, and then copy manually):
I don’t think I’ve seen a way to “hijack” the “paste link” command in Hook to add a bit of applescript that would add the note to the selected omniplan task.
I was thinking with the new expanded AppleScript capabilities in Hook 1.6, there may be a way, but my script-fu is nearing its limits…
