OmniGraffle: Deep links to specific shape or canvas
Hi,
Is it possible to deep links to a specific shape or canvas, etc., in OmniGraffle instead of a general link to a file using Hookmark?
An example would be two separate links, one for Rectangle A on Canvas 1 and another for Rectangle B on Canvas 2. So, similar to when you have links to specific pages or text blocks in a PDF.
Welcome to the Hookmark Forum, @hmp4581 . I have been using and loving OmniGraffle for at least 15 years. However, I don’t think they have a Copy Link function. If they did, then you could hook them together.
OmniOutliner has a copy link function. However at the moment one needs to create 2 links:
  1. link to entire document
  2. link to the OmniOutliner row
We could in principle support deep links for OmniOutliner using hook:// URL format if there was enough demand for it.
Hi @LucB ,
Thanks for the response and great info.!
I’d like to see support for OmniOutliner using hook:// URL format; hopefully, others in the community will also. :grinning:
I too have been using OmniGraffle for over 20 years with multi-canvas documents. As a result I’ve got a few hundred SVGs which I’d like to be able to link to specific canvases rather than take a guess!
