Hi. I just downloaded your app. It sounds really great. I can copy links fine, but I can’t link any apps together. The “Hook to copied link” is greyed out. I looked into the about window and it says my trial version is valid until April 13, but it also says “Hookmark Basic” and in another place (that I can’t find at the moment) it says I need to buy a license to gain access to greyed out functions.
Your website says that all pro features are available during a trial. Just the copy link alone is great and has me considering buying it, but I really would like to be able to try the other features before I buy. Anything I can do to enable them for the rest of my trial?
Edit:
Ah, I found it. Here you can see it says just basic mode is active and I need to buy to unlock the other features. But this is only my first day of the trial… I just downloaded it an hour or so ago.
Sorry about this issue. Yes, all PRO features should be available in Trial version. Obviously there is a bug there.
“Hook to copied link” button is only enabled when there is a valid URL in the clipboard and this URL hasn’t been link to the current bookmark. You can mouse over the button and see if there is any valid URL in the clipboard in the tooltip.
If you do “copy link” on a file, then go to a different file, invoke Hookmark window, is “Hook to copied link” enabled?
Also, could you please click on the sandwich button and take a screenshot of its menu, and post it here? I would like to see if the PRO features are enabled.
Ok. I opened the email to me about your reply and pulled up hookshot. I called up the menu and I selected copy link. Then I moved to nvALT and created a new file called “test hook”. I called up hookshot, and this is the menu
