Hookmark is not showing all my bookmarks for some reason. As. you can see from the screenshot there is 18 bookmarks but the list (or table view) only shows 7. It’s like the listing is stale. If I add a bookmark the “All Bookmarks” count will increment but the list will not show them. I have no filters or search set that I can tell. And the recent list will show the new bookmark but not this list. Any tips? Bug? Silly Human error? Thanks in advance.
I think I experienced a similar bug. What happens when you search for one of the bookmarks that aren’t shown?
For me, it is found and then shows in the list afterwards.
Welcome to Hookmark forum, @phantom .
Sorry about this issue. I can reproduce this issue. We will fix it.
Just want to make sure, if you restart Hookmark, will those bookmark show in Bookmark window?
Affirm. A restart does fix the issue.
@bchend - recent Pro subscriber and going through the forums to get up to speed. Do you have an update on this bug fix? I have the same behavior as documented above.
Additionally - My ‘recents’ seems to have all bookmarks whereas ‘all’ bookmarks only contains a subset. This may be expected behavior due to some sort of save-action I haven’t yet come across?
Welcome to Hookmark forum, @rocket21 .
Sorry about this issue. It will be fixed in next release(6.2).
This issue still exists for me though we are beyond (6.2). I have (6.10). And a restart does not fix the issue.
Welcome to Hookmark forum, @phantastes .
Do you mean the newly added bookmark still doesn’t appear in the Bookmarks window? I just tested it, and it seems to be working fine, though sometimes there’s a delay of a few seconds.
Could you let us know how you added the bookmark?
If I misunderstood, could you please provide more details about the issue?
Sorry for the delay. I have been traveling. Thank you for responding so quickly. Taking a closer look at my problem revealed that it was only happening when attempting to bookmark webpages in Safari. Links between items seems to work, but when I activate Hookmark on a webpage and activate the keystroke to save a bookmark without linking and used the shortcut to save a bookmark only, no bookmark is created. When I do this in Mail.app it works fine.
Thank you for responding to this difficulty I am having.
Thank you, @phantastes .
Do you mean “Add bookmark without copying”? I just tried that and it seems to be working fine.
Yes, I meant “Add bookmark without copying”. I just tried it on a few random webpages. A bookmark appears in “Recents” but not in “All Bookmarks”. Also renaming the bookmark doesn’t stick. Again, this happens only in Safari.
We will look into the issue.
I wanted to let you know that the book marking function is working as expected now. Thank you for your assistance with it.
Thank you for letting us know, @phantastes . I am glad it works.
