MindNode Next breaks Hook integration
The next-gen version of MindNode has significant differences in its file storage and management functionality. Originally, Mindnode documents were exposed in the file system and stored in iCloud. While the new version still uses iCloud, documents are technically stored in a database and not directly accessible by the end user. MindNode Next allows you to copy links to specific documents from within its integrated file manager, but those links are “MindNode.com” links. I can’t speak to whether they’re exposable through AppleScript.
We just updated our script server with the support for MindNode Next, script version 351. Please update your local Hookmark script and give it a try.
Hello,
I am on version 351 and Hookmark returns “No linkable item…” when i invoke Hookmark from both inside a document and from the file browser. Any ideas on how to troubleshoot?
Could you please open a mind map document , select a node and run the following script in Script Editor? Then post the result here.
Summary
use framework "AppKit"
use framework "Foundation"
tell application "MindNode Next"
	activate
set the clipboard to ""
delay 0.1
set theUrl to ""
set theTitle to ""
	tell process "MindNode Next"
		click menu item 16 of menu 1 of menu bar item 4 of menu bar 1
		delay 0.3
		repeat 10 times -- poll clipboard for ~2 seconds. Sometimes set x to the clipboard throws exception
				set theUrl to the clipboard
				if theUrl is not equal to "" then
			delay 0.1
		if length of theUrl is 0 then
			click menu item 13 of menu 1 of menu bar item 3 of menu bar 1
			delay 0.3
				delay 0.1
			set AppleScript's text item delimiters to "#"
			set theResults to text items in theUrl
			set theTitle to second item of theResults
			return "{\"name\":\"" & my base64encode(theTitle) & "\", \"address\":\"" & my base64encode(theUrl) & "\"}"
			set theUrl to paragraph 1 of theUrl
			click menu item 17 of menu 1 of menu bar item 4 of menu bar 1
			delay 0.3
					set theTitle to the clipboard
					if theTitle is not equal to "" then
				delay 0.1
			set theTitle to paragraph 1 of theTitle
on base64encode(str)
	return do shell script "base64  <<<" & quoted form of str
end base64encode
Hi, it duplicates the selected node with the following result:
“{"name":"U3R1ZmZlZCBNZWF0YmFsbCBhbmQgR2lhcmRpbmFyYSBQaXp6YQo=", "address":"U3R1ZmZlZCBNZWF0YmFsbCBhbmQgR2lhcmRpbmFyYSBQaXp6YQo="}”
If I invoke Hookmark while a node is selected, that node appears in the Hookmark window. But the link itself is just the text of the node with %20 in place of spaces.
What’s your MIndNode next version? Mine is Version 2025.1 (246).
Could you please post a screenshot for the following problem?
Thanks for sharing your version, there was a MindNode update available for me that fixed the problem. I’m now able to link to specific documents from within the browser as well as link unique nodes within a map (which is really cool!).
Thanks for the help here!
Hi, it doesn’t seem to work for me in MindNode Next 2025.7 (486), the first version of the app I’ve used. (Longtime MindNode user.) If I try to hook a document in the document browser, I get this error in Hookmark:
No linkable item found in MindNode Next. Can’t get item 2 of {).Please ensure the document is saved or you have selected an item. Learn more. Hookmark 6.11.1(6345); Integration v. 391
However, MindNode Next has a built in ‘Copy Link to Document’ option in the right-click context menu and the File menu. Does something need to be updated in Hookmark? Thanks.
Yeah, it seems that this broke again in a recent update. There may be a script update necessary but that’s beyond my skill level.
