Hi All… Does anyone know how to integrate Hook with Mindmanager? On the bright side, it seems to already work out of the box… Triggering hook on an active Mindmanager window shows the stuff you’d expect… The issue is pasting a hook link into the map itself: whereas in MindNode this would create a hyperlinked Node, in Mindmanager, it would just paste in the title… I think this is the only bit that needs to be tweaked
