I’m new to Hookmark and have installed Hookmark v6.0.1 I’m using MacOS 13.6.1 Ventura. Note that I install apps when in the admin account, but run things in a user account.
For some reason I cannot find or use the Hookmark Finder extension, despite looking in all the obvious places in the various library folders.
Can someone tell me where I can find it and if it’s not installed how I can install it.
If you go to System settings and search “Finder”, click on Finder Extensions->Added extensions, can you see Hookmark in the list? If yes, please turn it on. If it is on already, turn it off first then turn it on.
Thanks for the response. I’ve done that but the Hookmark extension isn’t listed. For some reason it doen’t seem to have been installed when I installed Hookmark. I think it should be in the system library folder somewhere.
Thank you. Running the terminal command did it and I can now find the extension.
Most of the extensions with the .appex extension appear to be in : system/library/ExtensionKit/Extensions and I was expecting to find the Hookmark Finder extension there.
Still, it now works so all is good. Many thanks for the help.
