Hello Everyone
Since I’ve been utilising Hook for several months, my workflow and productivity have risen significantly. It’s mostly used by me to link tasks, notes, and documents among various apps. But I want to make much more use of Hook in conjunction with OmniFocus and Evernote, two of my most important productivity tools.
I currently use OmniFocus to manage tasks and assignments and Evernote to take notes, summarise meetings, and save research materials. When performing tasks in OmniFocus, I frequently find that I need to consult certain notes, and vice versa. Although Hook already makes it simpler to link various apps together, there must be more effective ways to combine them together effortlessly.
I have the following specific queries:
Guidelines for Linking: How should linkages between Evernote notes and OmniFocus tasks be created and maintained? Are there any tricks or quick cuts that could make this procedure go more quickly? ![]()
Automating Procedures: Has anyone used Hook to successfully automate the process of integrating OmniFocus and Evernote? If yes, could you describe your methodology and any helpful scripts you’ve come across? ![]()
Managing Huge Link Volumes: The quantity of links in my projects increases together with their size. In order to keep a big number of Hook links manageable and prevent them from becoming overwhelming, how do you organise and manage them? ![]()
Extra Integration Advice: In order to increase productivity even more, are there any other programmes or devices that you’ve discovered work especially well using Hook, OmniFocus, and Evernote? ![]()
I checked this for reference
https://discourse.omnigroup.com/t/evernote-links-in-omnifocus/minitab
I would be very grateful for any information, resources, or experiences you could provide. Anticipating feedback from the community & discovering how to optimise Hook using OmniFocus and Evernote!
in advance.
