Hi all,
I’m building a Python- and Alfred-based research workflow that integrates Zotero, DEVONthink, Obsidian, OmniFocus, and Hookmark.
The automation does the following:
Creates a literature note in Obsidian, templated via Templater and populated from Zotero.
Locates the matching PDF (indexed in DEVONthink) and links everything together:
zotero://select/items/@citekey -
x-devonthink-item://... -
obsidian://adv-uri?...
Uses the
hookCLI tohook linkthese three items to each other – works beautifully.
I also have a read mode that creates a sequential OmniFocus project via JXA. This project includes two recurring daily tasks (e.g., “Read X”, “Process highlights”), tagged and estimated.
Here’s the challenge:
I’d love to Hookmark the OmniFocus project (and/or its top-level task) to the note (either directly or in Obsidian), Zotero item, and PDF (either directly or in DEVONthink).
But every time I run hook link obsidian://... omnifocus://task/..., I get bookmark not found.
I’ve confirmed that:
- The project is created and visible in OmniFocus
- The
omnifocus:///task/PROJECT_IDURI opens correctly hook linkworks fine with all other file/URL schemes (DEVONthink, Zotero, Obsidian, Finder)
But OmniFocus URIs don’t seem to be resolvable by hook, even if the project/task is in the foreground or manually opened.
My questions:
Is it possible to programmatically create Hookmark bookmarks for OmniFocus items (via CLI, AppleScript, or anything else)?
Can
omnifocus://task/...links ever be used inhook link, or are they not supported? -
Is there any workaround to make OmniFocus projects discoverable by Hookmark so they can participate in
hook linkautomation? -
Would pinning the project or task manually via the Hookmark UI make it available to CLI commands?
Thanks for any insight – and thanks for the incredible tool!
fort
