Hi all
I was wondering if via hook I can link to system contacts (Mac/iOS) possible?
ie search via recast/alfred a contact and then generate a hook link for that contact that would auto ope that contact card?
thx
Z
Hi all
thx
Z
Sorry it seems I am not understanding something here. could you please elaborate on your feature request?
Contacts is a linkable app for Hookmark. You can link a contact to other document.
Do you mean you want to do linking from Alfred?
thx @bchend !
ahh ok I didn’t know it already was (couldn’t see docs)
I guess yeah I wonder if there is a way to search via spotlight (ie Alfred/raycast) for a contact and hook it that way or do you manually need to open the contacts app?
best
Z
For now, manually open Contacts app is necessary. Maybe Alfred’s automation can help, I am not sure.
Yes, that works, by using addressbook://identifier. The identifier can be obtained from Swift. I am creating a PR for a contacts raycast extension in a few minutes. If you want to support me, consider using my affiliate link which will give you 10% pro: Raycast - Your shortcut to everything
