Limit how many backups are kept?
In setting up a new computer I noticed that Hookmark had created 60 gb of backups. Is there a way to limit this to, say the most recent two weeks of backups?
Sorry we don’t have a setting for the most recent backups.
Butyou can run the following command inTerminal.app to limit the number of backups of Hookmark’s database:
defaults write com.cogsciapps.hook database.backup.limit n
Just adding my 2 cents, in case someone else needs it: I don’t want a certain number of backups, for I don’t control how many backups Hookmark does (or will do in the future) in a day/week/month. I use Hazel to delete backups based on their last modified date. The backups are in ~/Library/Application Support/com.cogsciapps.hook
Thanks for this Hazel rule! I’d forgotten about the problem, and then I just discovered that I have 6 GB of backups! There has to be a better way!
@LucB Any way of building limits in?
For example, wouldn’t it be possible to have a setting or a startup question that corresponds to this:
defaults write com.cogsciapps.hook database.backup.limit 5 (or some other default)
Seems simple, and all those 100+MB backups seems like a lot of cruft.
Isn’t that exactly what that does?
Actually, this won’t work without changing “Name” to “Full Name”. See this for more info.
