Anyone using Keep It (reinventedsoftware.com) and working on integration?
Hi @rwread,
We haven’t looked at that software and have not had prior requests to support it. (I had an exchange with its developers about its predecessor, Together, in 2014.)
I had a quick look at the website and couldn’t see automation support. Have you tried invoking Hook in that app? Does it expose the address of its items (via a “get URL” command, for instance)?
Keep It has excellent AppleScript support (https://reinventedsoftware.com/keepit/applescript.html) so everything needed should be there. Links to everything are available so full functionality with Hook should be possible.
I’ve copied the Keep It developer here.
Thank you,
Thanks @rwread, I’ve added it to the list of apps with which to integrate.
They’ve also got callback links:
That’s for iOS. We’re looking into the Mac side.
With apologies for the long delay in getting to this one: Hook integration scripts v. 86 supports Keep It by Reinvented Software - Releases - Hook Productivity Forum.
