Issues with hooking from within MindNode Next (MNN ver 2025.6.2 (473), Hookmark ver (Version 6.11.1 (6345; Integration v. 386))
Having issues with a previously working integration. If I go to trigger the Hook context window from within a MindNode Next document, either using the KB shortcut or selecting “Show Hookmark Contextual Window” from the menu bar dropdown, Mindnode’s Edit menu will trigger and a dialog to rename the document will show. Then, the Hookmark contextual window opens with the following error:
Can’t get item 2 of {}. Please ensure the document is saved or you have selected an item. Learn more. Hookmark 6.11.1(6345); Integration v. 386
I’m inclined to think this is an issue with this specific script, Hookmark works normally in other applications.
Any ideas on how to further troubleshoot?
Thank you for reporting this issue, @jmbrysk .
The script for MindNode is UI based. If the UI is changed, the script will not work.
We have updated the script server. Could you please update your Hookmark script and see if the issue is fixed. (Hookmark settings window->Update->Check now) . The script version is 387.
Hi bchend,
I have grabbed the update and this seems to have fixed the issue! Thanks for your efforts here!!
Jim
