Hi, I know Hookmark doesn’t work well with Ulysses. But every time I launch Hookmark in Ulysess, it always brings up a Textexpander window. (please see the screenshot.)
Is there any way not to let the Textexpander window pop up? Thanks.
Sorry about this issue.
The script for Ulysses uses option + control + command +c shortcut to copy the note ID.
Is that the shortcut to invoke TextExpander on your mac?
Hi, Thanks for your quick response.
Yes, I do use option + control + command +c for TE.
Is there any way to modify the shortcut in the script for Ulysses. Or I have to change my shortcut for TE?
Stephen
Perhaps it is easier to change the shortcut for TE.
I am not sure there is a way to change the shortcut in Ulysses.
Noted. Thanks again.
