Announcing a new version of Hook beta: Version 1.0-beta (1999) built 2019-02-11
Fixed:
ID Comp Summary
3084 Integrat Bookend integration bug
2809 InputW: Do not draw a grey line above or below the selected menu item
3088 Default Devmate crash report
New/improved
ID Comp Summary
2948 InputW: Additional shortcut for “Link to Copied Address”
well, until we sort out the in-app update, users should be able to download directly from https://hookproductivity.com/download . I did test the URL, and the build available from it (1999).
OK. I’ve disabled 1999 from devmate and changed the download page to not refer to 1999.
1999 had some junk meta-data in it (my bad) which caused the update from prior builds to fail. (I had dropped the .dSYM file into the “delta” well rather than the .dSYM well on DevMate.)
But if you have build 1999, you can still use it. It’s got some bug fixes. We will roll out a new DMG this evening that has no real software changes in it compared to build 1999 – just so that we can fix the associated meta-data.
SORRY for the confusion. But thank you for your patience in helping us get these these processes down pat during our beta phase.
