I tried to integrate Goland with Hook and found that the current IntelliJ IDEA integration is not ideal.
Current Goland/IDEA supports internal jetbrains:// links to project, file in the project, and cursor position.
I created a script for creating a link and getting a nice name.
Get link
This script creates a link to the whole project because the link to the cursor position or file is pretty unuseful. It can be easily updated to get a link to file instead.
Preparation
You need to setup a keyboard shortcut for “Copy path…Toolbox URL” from keymap settings. In my case its ⌃⇧⌥⌘+С, if you choose differently — you’ll need to update the script.
Also, for IDEA/rubymine/pycharm users - you need to update application id from com.jetbrains.goland to id of your app. You can find this ID by passing to console osascript -e 'id of app "Goland"'
Script
set the clipboard to ""
tell application id "com.jetbrains.goland"
activate
keystroke "c" using {shift down, command down, option down, control down}
delay 0.1
set fp to the clipboard
set AppleScript's text item delimiters to ":"
set theTextItems to every text item of fp
set result to (text items 1 thru ((length of theTextItems) - 2) of theTextItems as string)
get result
Get pretty name
The same thing, don’t forget about the custom shortcut.
activate
delay 0.1
set AppleScript's text item delimiters to "project="
set parsePjName1 to text item 2 of (every text item of fp)
set AppleScript's text item delimiters to "&"
set result to text items 1 thru ((length of every text item of parsePjName1) - 1) of parsePjName1
get result as string
I assume that the first script may need to be updated to create a link based on project name, but on another side, some of you may want to have a link to the specific file, instead of the link to the project, so I decided to leave the first version of the script as more hackable option.
