Notenik is a free note-taking app made specifically for macOS. It has been around for a few years and was featured in Issue 310 of MacStories Weekly (2022-03-04). It stores its notes as plain text files, “You can format your notes using Markdown, with support for footnotes, citations, definition lists and MathJax. Use wiki-style double bracket notation to link from one note to another. Automatically generate a Table of Contents for a single long note, or for an entire collection of notes.”
Its developer, Herb Bowie (@herbbowie) / Twitter, today made his app linkable.
Herb even donated integration scripts which you’ll find on APIs for Hook Integration.
Get Address
The following script can be placed beneath the
Get Addresstab in the Scripts section of Hook Preferences.tell application "Notenik" if HasSelectedNote then set theTitle to GetSelectedNoteTitle set theUrl to GetSelectedNoteBacklink return "[" & theTitle & "](" & theUrl & ")" end if end tellThis script allows Hook to ask for the Title and the Backlink (see Custom URL Scheme) of the last Note to be selected. This information then allows Hook to later communicate with Notenik in order to pull up that same Note.
New Item
New Itemtab in the Scripts section of Hook Preferences.tell application "Notenik" return AddNote title "$title" link "$user_link" tags "hook" end tellThis script also returns the backlink to the Note of interest.
Tips for Hook Integration
You will want to make sure the Timestamp field is included on any Collection you wish to use with Hook. This field allows Hook to reference a Note even if it has been renamed.
I did a first quick round of testing the integration and found it works well though in one case the Hook to New may have failed to establish the Hook. We need to look more carefully before sharing this on the integration server.
If anyone would like to try we’d appreciate your feedback.
