Dear Dr. Luc P. Beaudoin,
After updating to the latest Hookmark ver. 4.0 (4988 :Integration v.240),
some macros in Keyboard Maestro (ver. 10.2).
Shortcut for ‘cmd+F12’ set to ‘Change Colour of Text Selection’.
The “cmd+F12” shortcut no longer works.
It worked fine in the previous Hook 3 app.
What if I Quit the Hookmark 4 app itself?
How does Keyboard Maestro behave?
I experimented with this.
If Hookmark ver. 4.0 is not running.
This macro worked and the font and text size changes
restored.
What & where can I do to get it to behave like it did in the original Hook ver. 3?
As a ‘matter’ that seems to be related to this, I have tried to initialise the Bookmark DATA in Hookmark’s.
How can I do this initialising the Bookmark DATA?
I would be very grateful for your advice.
Respectfully yours, WAKAMATSU kunimitsu
Newly reworked macros for Keyboard Maestro.
It is now possible to change the size and colour of font text
even when Hookmark 4 is running.
It takes a little longer to convert than before, though.
I am sorry for the trouble I have caused you,
And apologise for any inconvenience caused.
